Adjust items - channel possible for min and max values and step size
Laura 5 years ago in IQANdesign • updated 5 years ago • 2
Is it possible to add to the value types a channel? We have several situations that the min or max value of a parameter should be different. When I can use a math channel I can use a state to change the values. Or can somebody give me a workaround?
Kind regards Laura
Image 2968
Are the limits different due to different machine models? And fixed once you have configured the machine in model in production.
In that case, a workaround may be to have multiple FP channels, use a state parameter to select between them in the application logic, and use visible property to only show one to the user in the menu system
FP selection.idsx
I do not think a channel could work on these properties. The min and max property value needs to be known in order to check the limits. This needs to be done before using the parameter channel. But channel value are only known after the application has started.
Thanks for your answer, I will try that method
Kind regards
Laura
