J1939 import: DP bit of PGN
Richard Gagnardot 5 years ago in IQANdesign • updated 5 years ago • 2
Yesterday, I tried to import a J1939 dbc but I had an issue. I have 2 IDs,  CEFD1EF and DEFD1EF, with the PGN EF00 and 1EF00. When I try to import these 2 messages, I get a random result: I sometimes obtain 2 messages with the data mixed on eachother, or 1 message with the data of the 2 messages, and the PGN read by Iqan Design is always EF00 (61184).
The work around I found is to import the messages with PGN 1EF00 and change the PGN imported from 61184 to 126720, then import the message with PGN EF00.
I concluded that the DP bit is not read or not correctly imported. In your opinion, is that an importation bug or a bad DBC configuration?
Image 2990
Image 2991
Image 2992
Satisfaction mark by Richard Gagnardot 5 years ago
Perfect timing on this question, I am just going through 6.08 release notes where we have a fix for DP bit in DBC import.
So it is a bug, fixed in 6.08.
The release is still a few days away.
Oh, good, thank you for your quick answer!
