Image size
Tim M 5 years ago in IQANdesign • updated 5 years ago • 2
When adding a J1939 image from the library in the latest version of IQANdesign, it no longer allows you to customize the image size.  It adds the images as 50x50, which is much larger than I want.
It sounds as if you mean the ISO symbols, and the new SVG support. This was introduced with IQANdesign 6.05.
When using an SVG on a display page, you now scale it with the width and height properties on the page where it is used. No need to decide on the size when importing from the image library.
OK, got it.  I didn't realize that this had changed.  Thank you for your help.
