Export .dbc with Multipacket Dynamic Text Parameters
Chris Litwin 5 years ago in IQANdesign • updated 5 years ago • 2
I recently tried to export a dbc file that contained a multipacket JFIN with dynamic TPINs. The exported file does not include the TPINs.Export dbc test.idsx
IQANdesign only support export of value parameters to DBC files.
I might be wrong here, but when I look at the CANdb++, it appears as if there is no support for signals with value type text in the DBC format.
From what I can tell, it seems as if text value type ASCII and Unicode are only available with the Vector MDC format.
Ok, so DBC files in general don't support text parameters?
Thanks,
Chris
