Diagnostics Bus Shared
Doug Coutlee 5 years ago in IQANdesign • updated by Thomas Moberg (System support) 5 years ago • 1
Why do I get a project check warning about this? I do have G11 and a GT module on the same diagnostics bus but why is this a problem?
Image 3030
This is a warning that the Diagnostic bus is on the same bus as another type of bus in the system layout.
We normally reccomend to have the diagnostic bus on a seperate bus as the bus load can varry a lot.
