clone firmware version
Evert-Jan 5 years ago in IQANrun • updated by Gustav Widén (System support) 5 years ago • 2
When I try to send a clone file with Run6 in a MD4-7, I get the  message below.
Probably the firmware in the clone file is to old for new display.
Image 3033
Does anyone have a solution for this? I only have this clone file, not a project file or settings file.
I can usually get around this by sending blank application files to incrementally downgrade the firmware. Once you're at the correct firmware you can send the clone.
There's a knowledge base article with a warning related to this. https://forum.iqan.se/en/knowledge-bases/2/articles/2003-iqan-md4-7-display-update-use-version-40715-or-later
You can check the firmware version in the clone by right-clicking on the file in Windows explorer.
I am guessing this is an MD4 with the most recent display, and a clone that contains firmware 4.06 or older.
As Chris points out, there is an important warning about older firmware for MD4. Version 4.07.7 locks the module, and the check cannot prevent this.
