IQANdesign 6.08 No Bluetooth Menu
Hank 5 years ago in IQANdesign • updated by Gustav Widén (System support) 5 years ago • 7
I'm using:
Image 3037
but I have the following Communication menu:
Image 3036
I'm missing the Bluetooth option.
I have uninstalled and re-installed with the same results. What else can I try?
Answer
Answer
The Bluetooth functionality requires Windows 10 with build number 15063 or newer to be enabled.
Simply switching Bluetooth off or putting the PC in flight-mode does not remove the Bluetooth menu option.
But I think it is worth checking in Windows device manager also, to see if there is anything that looks strange with Bluetooth adapter there.
If you are using a shortcut (on the taskbar for instance) - you will need to update the shortcut to point to the new location for IqanDesign 6.08 - it will still be opening 6.07 (or earlier) if you don't.  If you double-click an .idax file it will open in 6.08 (latest version)
Update:
The Surface Pro laptop I was using is too old. The chipset is up-to-date, Bluetooth drivers are up-to-date (for its age) and the Bluetooth is working but the Bluetooth Menu in IQANdesign 6.08 is still not being displayed. Yes, I checked to make sure it was opening IQANdesign v6.08
My newer laptop (bought in 2018) shows the Bluetooth menu option without installing anything extra (Bluetooth related). So this is the solution... I can't use the older Surface Pro.
Interesting - was the Surface Pro running Windows 10?
Answer
