Display channel value in interactive message like in conditional message
Jacob Meng 5 years ago in IQANdesign • updated by Gustav Widén (System support) 5 years ago • 1
I have noticed that a conditional message can display another channel value. This is handy especially when using the message to notify the user that a parameter is out of spec. I am using an interactive channel for the same purpose but it does not appear to be able to display a value from another channel in the same way. Is there a way to do this?
Image 3092
Image 3093
If you are ok with only sampling the value when the IMSG is triggered,you could pass the channel value via a TFC connected to the IMSG text property.
