Simulating digital inputs
Tim M 5 years ago in IQANsimulate • updated by Gustav Widén (System support) 4 years ago • 5
If I run a simulation using IQANdesign/IQANsimulate 6.08 with all digital inputs used, DIN-A through DIN-T all show OK, while DIN-U through DIN-AR all show False: Disabled.  If I do the same thing with IQANdesignIQANsimulate 5.05, then all digital inputs show OK.  Can you explain this?
Satisfaction mark by Tim M 4 years ago
I noticed a similar issue.  In an IQANdesign 6.08 project run on the 6.08 simulator, the four sinking inputs show disabled.  If I start a blank project on an MC43 in IQAN 6.07 or earlier, the inputs work fine in IQANsimulate 6.08.  I'll be trying this on hardware in the next few days.
Planned
Confirmed this is a bug in IQANsimulate 6.08.16
DIN-U and higher stay in disabled status, affects simulation of MC43 (but not the expansions).
Will be fixed in a 6.08.x update of IQANsimulate.
