Calculation order dialog opens without buttons
Pierre Fagrell 5 years ago in IQANdesign • updated by Gustav Widén (System support) 4 years ago • 2
Sometimes, if the Component Navigator is open on the secondary screen, when opening the Calculation Order this new dialog window will be without any buttons. Resizing the window does not help.
Even if I close calculation order window and reopen it ten times it still does not have any buttons.
Image 3121
However, if I close and reopen the Component Navigator, then the next time Calculation Order will have buttons again.
Image 3122
Satisfaction mark by Pierre Fagrell 4 years ago
Started
Thank you Pierre. Seems to be caused by different scaling on the extended display.
Will be fixed in next IQANdesign update.
