license key for bluetooth connections with IQAN RUN
Lorenzo Simonetti 5 years ago in IQANrun • updated by Gustav Widén (System support) 5 years ago • 1 • 1 duplicate
I haven't received an email with the correct key for the 10 bluetooth connections with IQAN RUN, where can I see my key? I can't work without these connections.
Thank you.
Best regards,
Lorenzo Simonetti
Duplicates 1
You are probably referring to the IQANconnect remote connections.
(Local connection directly from IQANrun via Bluetooth does not require any other license than the regular IQANrun license)
To find the license keys, you will need to know the email address that you used when ordering. With this you can log on here:
https://iqan.onfastspring.com/account
