Turn off MD4 Display
Gord 4 years ago in IQANdesign • updated by Michael Carlyle 4 years ago • 1
Is there a programmatic way turn off a MD4 display but leave the controller and program running in the background?
Backlight control can be turned down.
Backlight control
Controls the backlight of the display. When connected to a channel its value overrides the value set in the display's menu system. To use the setting in the menu system this property has to be set to Not used.
Value types: Constant, Channel
Component value types: Integer, Real
Unit: %
