+3
DM1 Occurrence Count
EmilFernlund 4 years ago in IQANdesign updated by Gustav Widén (System support) 3 years ago 1
Would be great if the DM1 messages from the "DM1 out" also sends Occurrence Count.
As it is now it always sends 127 which makes the DM1 messages in IQAN Connect portal not work as desired.
I think OC would be a necessity if we were to add support for DM2 (previously active DTCs ).
For DM1, I think it is mainly the current status that is interesting.
After some discussion, it seems as if the DM1 need is due to a bug/limitation in the current implementation of the Mobile IoT telematics system. Fixing this should be a priority.
