How to set up multiple camera inputs?
Deanne 4 years ago in IQANdesign • updated by Thomas Moberg (System support) 4 years ago • 2
Is there a way to toggle between multiple cameras? Since there is only one camera input, does some sort of relay or switch need to be implemented?
You can use both ports with 2 Iqan SV cameras on one MD4.  If you want to use other IP cameras you will need a router and set them to different IP addresses (192.168.128.X - where the X number should be different for each camera).
To connect multiple cameras you will need a ethernet switch/router that you connect both cameras and MD4 to.
In IQANdesign you add as many cameras as you want to connect and define what cameras are connected to what camera feed on the display pages.
Then in the menu system of the MD4, after the application is downloaded.
You go to System/Cameras and you can see the different cameras that you added in IQANdesign.
Here you need to go in to each camera and assign them a camera that is found on the network to connect them.
