Remove Custom CAN Databases from Project
Chris Litwin 4 years ago in IQANdesign • updated 4 years ago • 3
I have imported a couple custom CAN databases to a project and now it will not let me remove them. I assume it has something to do with the original import file being moved or renamed. How can I remove them from the project with the remove button grayed out?
Image 3207
Hello Chris.
This sound strange.
You should still be able to remove the CAN database from IQAN even if the .dbc file is removed or othervise edited.
The CAN databases are stored under the hidden folder "C:\ProgramData\IQANdesign 6\CAN Databases". Depending on which user added the database to IQANdesign it could be restricted for other users on the computer. If you have administrator rights on your computer you can either remove the CAN database file manually or launch IQANdesign as administrator to be able to remove it from IQANdesign.
Anders,
Removing them manually from that folder worked. Thank you.
