+9
Simulation Battery voltage
Joe 4 years ago in IQANsimulate • updated by Rick Yorke 10 months ago • 6
Is there a way to change the +BAT diagnostic channel during simulation? I am doing some demonstrations that use this value to show engine charging voltage and it is stuck at 12.40V. I have a 24V system, so a low voltage error is persistent.
Unfortunately not, the +BAT value in simulation is fixed. It only changes if you set the module status to Low supply, then it changes to a value below this alarm threshold.
I can change the topic category from Question to feature idea if you like?
Yes, please do. I think this could be expanded to include all the diagnostic channels so that simulation of things like module status change could be shown. Thanks
I would like this as well, it would make it easier to simulate alarms for under voltage and over voltage. To test my code I had to take out an MD4 and connect to a variable power supply.
Hopefully this gets picked up, I'm running into the same problem now
Agree with these comments. What is more frustrating is in my simulation the MC reports ~12v while the XC is reporting ~24v.
Running simulate 7.05.14.7291
