Have any way to CRC parameter only concerns PGN not ID
hongxiang yu 4 years ago in IQANdesign • updated 4 years ago • 2
The type of CRC parameter that is only SAE-J1850 CRC-8 incl ID or SAE-J1850 CRC-8  for selection.  But i have a case that is SAE-J1850 CRC but it requires PGN not whole message ID.  How can i do to make it possible in IQANdesigned
What you could do is to configure it to only look at data field in IQANdesign, and then just use a different seed value for the different PGNs.
Would you teach me how to calculate and set the seed value as example PGN is 65362 .
