Generate random number
Samuel Pittet 4 years ago in IQANdesign • updated by Gustav Widén (System support) 4 years ago • 1
Hi, is it possible to generate a random number in realtime in a IQAN Design program? I'm using a MD4-10 and a MC43-FS in my system.
I do not see such a feature/function at the moment.
Basically, generating a random number between a specified interval of numbers.
Yes, there is the function Random that you can use either in Qcode or Object list.
It gives a random integer between 0 and the operand - 1.
For example:
Radom(10) gives a random integer number between 0 and 9.
