+3
/n new line in imsg/cmsg
Mack 4 years ago in IQANdesign • updated by Marcel 3 years ago • 4
Request to add new line feature (\n or _ notation used in QCode would work) for IMSGs and CMSGs.
Satisfaction mark by Mack 3 years ago
The CMSG and IMSG will wrap automatically, but I can see the need for controlling the line break.
A trick you could use is to enter text also on the line for help. But that shows up as a separate paragraph on the MD4 popup message.
I found that using the help/channel lines changes the line spacing which looks odd. One need for this is creating a list in the message. My case I was trying to copy the format/style of the native error codes where it reads out the pin and module on separate lines.
Line break implemented in 7.01
57674Control CMSG/IMSG line break
Text and help properties are now multi-line.
Is it also possible to use a linebreak in an Text formatting channel for example?
