Small gui improvements IQANdesign
Pierre Fagrell 4 years ago in IQANdesign • updated by Gustav Widén (System support) 4 years ago • 1
I have a couple of small requests to make usage easier.
When doubleclicking for example in a name field with two words it selects the 1 word you clicked on.
In other Windows programs or in this forum for example, triple clicking selects all words in the field/row, that would be handy to have in IQANdesign aswell. Especially when creating new channels with long default names like "Dual Direction Math" or when creating many states/text parameters for engine fault codes.
When clicking on a state function the last selected tab/state is shown, the name does not have a box around it so you can edit the state function name.
If you click on a state name then it gets a small gray box around it and you can edit it's name.
If you create a new state the name does have the small gray box around it, but if you type in a new name you will edit the name of the entire state function, this is opposite to the behaviour above.
