Is there a way to detect if any message dialog is active so camera window can be hidden.
Lars Olsson 4 years ago in IQANdesign • updated 4 years ago • 2
Due to the camera window overlapping dialog windows I look for a way to see if there is any dialog open at all, which I could use to hide the camera window temporarily.
Hi, you can use the system information channel to get the "Active messages" status:
Perfect! That's exactly what I was searching for.
Thank you Arno!
