Unable to assign 29 bit CAN ID to GFOUT
Mark Bevington 4 years ago in IQANdesign • updated by Gustav Widén (System support) 4 years ago • 1
I don't understand what is going on in v6.08 IQANdesign.  I can no longer assign a 29 bit CAN ID to a GFOUT.  When it's first assigned everything seems okay, but as soon as you run Project Check, it then flags the ID as "Value not within limits".
NOTE:  The ID I am attempting to use IS WITHIN LIMITS as it is less than 536,870,911 (0x1FFFFFFF) as detailed in the text explanation box.  Did v6.08 break this ability????  See below:
Image 3332
On the bus, there is a property to define identifier size, 11 or 29 bit.
If the module the GFIN or GFOUT is located on is assigned to a bus with 11-bit identifier, you will have the project check error.
The value range shown in the property hint is not updated automatically with the bus the channel is located on, hence the text above that gives the value range for 11-bit identifier.
