initialization power reset
akira IQAN 4 years ago in IQANdesign • updated by Gustav Widén (System support) 4 years ago • 2
i have an initialization function group that can change the baud rate, but i need to manually turn the iqan MD4 on and off for it to take effect. is there a way to do a soft reset through iqan design?
If you make the adjustment via IQANrun, you could run a script in IQANrun that has the Restart master script action.
Image 3495
