Not a bug
IQANrun's imposed COUT limitation when adjusting Min current remains on controller after lost connection.
Johan Palm 4 years ago in IQANrun • updated by Gustav Widén (System support) 4 years ago • 1
When adjusting the minimum output current of a COUT, IQANrun imposes a limitation on the COUT equal to the set minimum current.
If the controller drops the application, without a graceful disconnect, e.g. if you do not first disconnect IQANrun before you connect with IQANdesign, then the imposed limitation on the COUT remains. This can cause a lot of confusion if you are unaware of this functionality.
It would be preferable if a dropped connection immediately removes the current limitation on the COUT.
Not a bug
I can confirm that this is how the min-current limitation works, it stays effective also if connection is lost.
It is not a bug, staying with the limitation is in our opinion the most predictable choice of action in case of an error. A realistic scenario could for example be if the diagnostic CAN bus is cut wile adjusting.
I think the main point that is good to be aware of is that there can only have one diagnostic session running at a time.
If you are connected with IQANrun and for example start a measurement in IQANdesign, IQANrun is abruptly disconnected.
