Problem with entering negative number into a lookup table
Andy 4 years ago in IQANdesign • 0
Hey Guys
In 6.08.24 there is an issue entering negative numbers into lookup tables.
like this
Image 3626
The table recognizes an edit is occurring when you select a cell in the table and press a number to enter the new number. If the number is a negative number you have to press, for example:-
[any number key][backspace][-][2][.][5][Enter]
The detect edit should have the negative key added to the number keys as valid keys to start an edit.
For my specific table I had it configured as a row only select table (ie one set of input data and one column of output data) with interpolation turned on.
I see this as a very minor annoyance......not even really a bug....but it would be good in time if it was fixed
