Property Inspector Input Channel - "contains" search, or Boolean search
cdvorak 11 years ago in IQANdesign • 0
When selecting the input channel to be used for a gauge, or value on the display it is nice that you are able to just type in this field and it will bring up selections. However this only works if you start with the same name as the input channel. It would be great if you could use wild cards, boolean type, or "contains" searches in this field.
