MD3 problems (version 2.x application)
RichardKow 4 years ago
in IQANdesign
updated by Gustav Widén (System support) 4 years ago •
4
Hi guys,
1. Customer has faulty MD3 (installed 2009)
2. I have clone file (irc) together with settings (irs) for this application I can open both in IQANRun 2.63
3. Got new MD3 (shows version 4.07.13.3815 pn 200777793 sn 312040107), Information on this forum that MD3-M15 indicates that 2.63 should be OK to load.
4. When trying to load into new (using IQANRun 2.63)Â MD3 got the message
Any suggestion to solve it and supply customer with fully functional MD3
Thanks in advance
Kind regards,
Richard Kowalczyk MIEAust CPEng(Ret)
RKad Engineering
32 Kingussie Ave
Castle Hill NSW 2154
Australia
📲 :+61 (0)431 639 295
How are you connecting, is it over USB or over CAN? You will see this and the status in the lower right corner of IQANrun 2.
Even though the MD3-M15 still had a USB port, my recommendation is to always use CAN when connecting, it is more reliable. See USB to CAN interfaces / Knowledge base / IQAN
Forgotten to mention using CAN for transfer
Hi Gustav,
I believe I have solved the problem.
1. Using IQANDesign 2.63 opened clone file. Saved as .ida
2.. Opened .ida with IQANDesign 4.07
3. Updated program (where needed), it was time consuming, updated settings to be the same as original settings and loaded in new MD3-M15. Disappointed that I could not load program with IQANDesign 2.63 as noted.
Regards,
Richard
Ah, now I understand. That is due to a change in diagnostic protocol that was made between versions 2 and 3 in 2012.
You could have used IQANrun 3, 4 or 5 to send the 2.x application to the module.
