set parameters on IQANrun not adjustable
Nathan Depcik 4 years ago in IQANscript • updated by Gustav Widén (System support) 4 years ago • 1
I am having an error while running a script on IQAN Run. "set parameter" from the script has an internal error that shows when running from IQANscript and IQANrun states "Failed to adjust the parameter. The parameter is not adjustable." this is happening for 3 adjust items and the rest have no issue. however when I "retry" it successfully adjusts this parameter but it takes multiple retries. once the first parameter is able to be adjusted the other 2 have no error when adjusted. I am running this from a command line prompt, but the issue happens if using the script function on IQANrun or running it from IQANscript.
issue was due to a delay causing a function group to be disabled causing adjustable not able to be able to changed.
