Accuracy of trigonometric functions
Theleo De Bruyn 4 years ago in IQANdesign • updated 4 years ago • 2
Hi there!
I have a question about the accuracy of triangulation calculation. A common math operator I use is "tan". I use this for calculating the slope [%] from the angle of inclination [°]. This has always worked fine for me but now I need a higher accuracy.
The Qcode I use in a math component:
Result:= tan(Angle)*100
Where:
Angle is in [°]
Result is in [%]
The result jumps from 0% to 0.17%. I would like to see an accuracy of 0.01%. Is there any other way to achieve this? Using sin/cos gave me the same results.
I have a Gyroscope Angle sensor with an accuracy of .01°. So the problem isn't the measuring.
Thanks in advance
Theleo De Bruyn
There is a limitation in the resolution on the trigonometric functions in IQANdesign, from the IQANdesign user manual:
Operand resolution for trigonometric operators is at least 0.1°. Result resolution is at least 3 decimals.
Depending on the application, you might be getting a more accurate result with other approximations, e.g.
Small-angle approximation - Wikipedia
Thank you for the quick reply. I'll try a different approach using the suggested approximations.
