Locking Objects (from Internal Analog in IQANdevelop)
David Lenz 3 years ago in IQANdesign • updated 3 years ago • 2
I am doing a conversion of an old IQAN system using the MDM screen with XS and XT2 modules. So far everything is translating over pretty clearly, but was wondering if there was any guidance on how to mimic the functionality of the Locking objects. From the IQANdevelop help file, it looks like if the Locking objects are true, it will freeze the output of the function.
Image 3715
In object list, you can make this with a dual channel that takes its own value when the lock is on, and the input when it is not locked.
Lock a math channel.idsx
