Not reproducible
MC43 code R4:1 6:1:6:2
Frederick Prigge 3 years ago in IQANdesign • updated by Gustav Widén (System support) 3 years ago • 10
Hi, I am getting the following MC43 code R4:1 6:1:6:2, it is not in the documentation. Does someone know what is the critical stop reason? I happens randomly at very long interval. Is there a list of all the codes somewhere or does someone know the meaning of that code?
video: https://photos.app.goo.gl/xbFbLxKePhzq28tz5
thanks!
Just realized I posted this in the expansion module sub forum. Admins, can you move it to the master controller topic? Thanks!
What software version is it in the MC43? E.g. 6.08.24
Is it MC43 or MC43FS?
Hi Gustav, I'm running on MC43 firmware  6.08.24.8051 (IQANdesign 6.08.30.8216). And it is a MC43 (not FS).
thanks!
Any news on this? I got R4:1 6 1 6 2 again this morning. It seems to always happen after I connect (via wifi) to the MC43 in measure mode in IQANdesign.
This one continued with some off-forum troubleshooting.
But to give a general comment here, some more details of the system would be needed to understand what is going on.
The part about WiFi as interface is interesting. Recently had another report of R4:1:n:1:6:2 where a loose Ethernet wire was identified as a problem. That was in a quite busy multi-master system, CAN traffic probably played a role too.
In this case (MC4x with version 6.08) the error code R4:1 6:n:n:n points towards CAN E. I suspect problems with the Ethernet connection, but CAN traffic might have something to do with it too.
Got the same issue this afternoon, I've a 4 nodes system (2 MD4 + 2MC43 modules). Only the last address ID node (add3) is not well "handshaking" with its fried. I tried to put a virgin project in it, push back an old version that used to work fine and I keep have problem with it. I've tried ethernet or CAN, both ways fails arround stopping the application running. Also running on 6.08.24.8051 for these MC43.
Apparently, it was possibly caused by a current return on an High Side digital output. Sounds like the application couldn't stop (requirement prior software update) while some current is flowing into its output  ¯\_(ツ)_/¯ ?! That's weird, but all communication and software flashing issues disappeared when I found and corrected this wiring mistake ! Good to know :O
Oliver,
Did you get the exact same blink code that Frederick explained?
If the module is started or restarted with the wiring error you describe, that should give a different critical stop blink.
