PDF file issue
Argy Tzouhas 11 years ago in IQANdesign • updated by Ulrik Zakariasson (Software development) 11 years ago • 3
I have been working with IQANdesign 4,01 and I am ver excited about adding the PDF files into my programme.
After loading all my PDF files and then assigning the action to the Text Labels and saving the file, the references are switched when I reopen the program. The text label that was assigned to open the Pump PDF file is now assigned to the Filter PDF and the Filter label is assigned to the Pressure sensor PDF etc...
I am not sure if I am doing something wrong or if I am doing something wrong.
Has anyone else noticed this issue?
Thanks this fix seems to have solved the instability related to the pdf file assignments.
Thanks
Satisfaction mark by Argy Tzouhas 11 years ago
There seems to be a problem when there are unused PDF files in the project. References to PDF files after the unused file will be wrong.
This issue will be solved in the next release of IQANdesign (4.02) which is planned within a couple of weeks.
