Can PIN codes be changed on adjust items from an MD4 screen?
jerry rowe 3 years ago in IQANdesign • updated by theo mastenbroek 3 years ago • 1
Add the Pin Code Channel to the top off your program. you can use the Pincodechannel as a pincode to a adjust channel.
to change the pin code ad the pin code channel to an adjust group
