Error when integrating external function
Chris D 3 years ago in IQANdesign • updated by Gustav Widén (System support) 3 years ago • 3
Hello everyone
I get an error in IQAN Design when I try to include an external function and the program crashes.
When I try to load the same external function into an "empty program" it works and I don't get an error.
However, if I try to integrate the external function into the software that we use in production, I immediately get the error and IQAN Design closes. Unfortunately I can't do anything with the displayed error.
Image 3867
Is anyone able to help me?
There is an issue in IQANdesign 6.08 when trying to add an external function that has translated adjust items. The issue has been resolved in IQANdesign 7.00.
As a workaround in 6.08, remove the translation for adjust items in the external function. Instead add the translation once they have been added in the main project. Renamed adjust items in the main project will not be overwritten when updating the external function so it should be a viable workaround until you decide to upgrade to 7.00.
Oh wow!  Yes now this works perfectly! Thank you very much!
Fixed in 7.00
58046Crash when adding external function with translated adjust item
Fixed.
