Adjust Item Enable Not Working
Chris Litwin 3 years ago in IQANdesign • updated by Gustav Widén (System support) 3 years ago • 3
I'm seeing an issue in IQAN7 and IQAN6 where if I create an adjustable state parameter, place the SP as a button on a display page, assign an enable property at the adjust item level, it will not enable the button no matter what state the enable property is in. I attached an example project file.
IQAN7 SP ENABLE TEST.idsx
I checked, if you use adjust groups these are updated. But not the display page controls as your example shows.
You can make the adjust item enable work on display pages if you have the enabling channel in the Initialization function group. Modified display page adjust enable.idsx
With the initialization group requiring a power cycle it doesn't work for my application. Can this be turned into a request?
