Iqanrun6 and 7 Password request to upload new project file
Matt B 3 years ago in IQANrun • updated by Gustav Widén (System support) 3 years ago • 1
trying to upload a parameter change file from factory to a module. I click send file using version 7 or new project using version 6. Both prompt for password as soon as I select file. I have another technician using same process and no prompt for password. There shouldn't be a password.
It sounds like the application has a Limited access password, and that your colleague has this installed on his PC as a Safe password.
You should be able to request a Safe password with Limited access from the machine designer.
