Is "Show send/get options dialog" no longer part of IQANdesign?
Kerry Brock 3 years ago in IQANdesign • updated by Gustav Widén (System support) 2 years ago • 4 • 1 duplicate
I was sending a project file to a system with IQANdesign 7 and the Show send/get options window was not popping up when I send the project file.  I checked in the Tools and Options section and did not see the check box or line to select this option.
IQANdesign 5.07:
Image 3930
IQANdesign 7.00
Image 3931
If the removal is intended, what are our options to select sending the options that were available here?
Duplicates 1
I believe they gave it a stand alone function.
Image 3933
Thanks Chris, that appears to be how it is handled now.
45867Import settings and reset settings menu items
Import settings and reset settings are now separate menu items under communication. Previously these were options for send/get project.
