Is the reset value on an event counter the same as a default value on start-up?
Deanne 3 years ago in IQANdesign • updated by mdonaldson 3 years ago • 1
I have an event counter in my program that is used to control 9 different setpoints, based on a button press. On start-up, I want the value to default to 6. Does the reset value on the event counter channel act as a default value?
As long as the 'store value' field is 'no'. Yes the reset value will be what is used on controller startup
