Cant connect via Bluetooth using Design 7.0?
Kevin 3 years ago in IQANdesign • updated by Gustav Widén (System support) 3 years ago • 2
We have a G12 installed in a system, and I seem unable to connect using IQANDesign 7. IQAN Run 7 works fine and I can see values etc but if I monitor in IQAN Design it refuses to connect. The flash sequence on G12 is 'connected' but I cant seem to get it to work, it eventually errors.
I may be missing something, does anyone have any advice? IQAN Go on the mobile appears to work fine, no issues.
Image 4007Image 4008Image 4009
I have exactly the same issue as you.
My system consists of MD4+MC42+MC43+G12.
The Ethernet-cable works just as it always did, but it would be nice to be able to connect IQANDesign through Bluetooth.
I recommend trying with IQANdesign 7.01 released earlier this week.
With IQANdesign 7.01, a number of Bluetooth issues have been resolved.
