IQANScript to connect using IQANconnect key instead of machineID?
Jean-Philippe Parent 3 years ago in IQANscript • 0
On the production line, the IQANconnectkey is written down by the operator in our system at the same time as the machine ID is set manually in the truck. Depending on the operator, the machine ID set in the truck might be different than the machine ID in our internal documentation.
IQANscript uses the machine ID instead of the IQANconnect key. Is there a server somewhere accessible to correlate the IQANconnectkey and the machineID set in the machine?
