Array in Initialization
Brendon 3 years ago in IQANdesign • updated by Gustav Widén (System support) 3 years ago • 3
Would be nice to be able to using an Array in Initialization.
I'm currently storing Screen ID's in an array, this array doesn't change so would be nice to initialize it, and not have it calculating each cycle.
I'll likely post a second idea about this, but on the topic of Arrays, would be nice to be able to store text in a Array.
Did you see the array property for Default values?
Image 4055
Would be nice if there were a description per index, but I suppose I could use a comment.
That said, I'll likely continue using my qcode as I can include my comments on the component.
Thanks though, may be able to make use of this elsewhere.
