Resize channels
jan 3 years ago in IQANdesign • updated by Gustav Widén (System support) 2 years ago • 5
Once resized single or multi channel, it is not possible to return to original size,
only able to return to original size + appr. 2 grids
Is this normal ?
No Issue with function groups
Hello Gustav,
I just discovered that the resizing to original size issue appears when the functiongroup workspace has been zoomed out (-)
I need to zoom in (+) several times to resize to original size.
There is also a size problem at workspace 'System Layout':
When application is updated from 6.08 to IQAN 7.00, and you add a new module.
Image 4061
The new module has a large size, and not able to be resized
The grid snapping did not scale with zoom or screen DPI.
Fixed in IQANdesign 7.03
