Function inspector Design 7
Ed Schippers 3 years ago in IQANdesign • updated by Gustav Widén (System support) 3 years ago • 3
In Design 7 I'm missing the pin function on the function inspector window.
Will this be added again in a future update?
It is a bit annoing, that when working on the bottom of the page, every time it pups up again it overlaps the bottom of the page and you need to scroll down to see the part that you are working on
Image 4058
Satisfaction mark by Ed Schippers 3 years ago
Planned
The icon for pin/unpin is missing in 7.00 (and 7.01), will be added back in in 7.02.
The function to pin/unpin still exists, it sounds as if you have it set on not pinned.
Thanks, If the function still exists where can I set this pin
I checked the optoion's but i can't find it there
