Analog Throttle Control - Mechanical Engine
Ryan Bland 747 3 years ago in IQANdesign • updated by Thomas Moberg (System support) 3 years ago • 1
Firstly Can the Polarity of Two Outputs be Reversed in order to Change direction of a Motor ? If not i can used a single digital output via two relays to reverse the polarity !
I would like to fit a Potentiometer controlled throttle to my machine , I would have a 5V input for the Throttle Request and the Linear actuator im going to use has a feedback potentiometer installed to give me actual Throttle Position , Can some help with the code to do this , When the Throttle is increased in the cab the Mc42 Needs to output 12V till it reaches the actual on the linear Actuator - The linear actuator needs to always equal what is requested in the Cab -The Actuator requires reverse polarity to Retract
Can someone please help with the PID loop / code to make this happen ?
Help would really be appreciated as im new to this - Many Thanks
Sounds as what you want is an H-bridge configuration but there is no good way of setting up a H-bridge with the MC42 outputs.You could do it with a pair of XA2 COUT:s combined to one 2A H-bridge but the XA2 is very soon not avalible for order any more. Last time buy is at the end of this month.
