Communication error
A DOMS 3 years ago • updated by Gustav Widén (System support) 3 years ago • 4
I have still lot of problem with IQANrun 7.01
I can't connect with IQANrun 7 to a machine that had a 5 or 6 version programme.
I have this error :
Image 4112
And when I connect with the computer of my technicien, I can connect but if I try to get a clone, after few minutes it doesn't work and it shut down the main calculator :
Image 4110
If I try again, I have this :
Image 4111
I could update the soft with IQANrun 6 to put a 7 versus to the MC43, but I can"t connect with IQANrun7...
Still the first error message.
Sorry but a lot of problem with this last version of IQAN 7.
Is there a way to save an IQANdesign7 project to IQANdesign 6 ?
This was first posted in IQANrun 7.00 - Bugs report / Software / IQAN, moved to a separate topic as this one seems to be about IQANdesign as well.
I'm confused by the first part of this post, where it says "I can't connect with IQANrun 7 to a machine that had a 5 or 6 version programme." but shows a printscreen of an IQANdesign popup with socket error.
Did you have IQANdesign 7 connected to the system before trying to connect IQANrun?
The second part is clearly on IQANrun as it shows a get clone operation.
But it seems something is also happening with the controller, "it shut down the main calculator".
Do you mean the MC43[0] stops its application? What does it show as a blink code?
What SW version is in the MC43s ?
The last dialog box with Incomplete system does indicate that the MC43[0] has stopped responding.
I think I understand the first message Error socket #10061.
I'm not sur, but I think my IQAN app was set to communicate with a simulator, and no simulator was open.
I think this is my problem and I didn't saw it because the error message doesn't explain the problem.
My bad for this subject.
For the second problem, I have it since the beginnig that I use IQAN7.
Each time I try to get a clone, the main calculator shut down and I have to restart the machine.
On the main calculator I have 4 red + 3 yellow.
Image 4122
and on the second calculator I have 3 red + 1 yellow
Image 4123
It's not the same machine, but the same problème :
Image 4124
Thank you, that explains the IQANdesign communication error.
For the the critical stop blink that starts with 4 red and 3 yellow will also be followed by a longer sequence, that could shed some more light.
But I think I know what it is. I see from the module info that you have 7.00 in the module, and in version 7.01 there is a fix for a problem with the exact same symptoms; an MC4 critical stop when getting clone. See release notes case 59386.
