Printing pressure transducer readings from MD4 display
Deanne 3 years ago in IQANdesign • updated by Gustav Widén (System support) 3 years ago • 1
For a customer application, they want to print pressure transducer readings that are stored in a MD4 without the need of a laptop. In searching for solutions, some people have suggested to have a gateway and a serial port printer. I am unsure of how to implement logic to communicate with a serial port printer. If anyone has insight on this, that would be greatly appreciated.
It sounds as if you have been given the right advice, the solutions I've see are with a CAN to RS232 gateway.
The tricky thing is to find a gateway that is easy to program, you may need to bring someone in to help you with that part.
