Static IP
cdvorak 3 years ago in IQANdesign • updated by Thomas Moberg (System support) 3 years ago • 1
IQAN Design 6.08
MD4-5 Master module
Simple application no code just for testing remote connectivity via telemetry gateway.
For some reason in Ethernet settings for the display I can not select and set Static IP, only default is available in the drop down selection. What am I doing wrong?
You dont use the drop down for the static IP, you just type the desired IP where it says Default.
