IQANRun 7.01 Measure Statistics doesn't appear to work
705David 3 years ago in IQANrun • updated by Gustav Widén (System support) 3 years ago • 2
The Statistics Window of IQAN Run 7.01 Measure screen doesn't appear to work.
I would expect the Value 1, Value 2, Min Value, Max Value. Peak to Peak, Rise Time, and Mean Value would populate when you select a signal in the Graph Items Window.
These values always remain 0
Satisfaction mark by 705David 2 years ago
You are right, something is not working with the IQANrun 7 measure statistics. The problem seems to be that statistics is always showing the first measure item in the group, and not the selected item as it should.
