Planned
Public scope channels referenced by logs give Qcode error "component name not unique" in 7.01
Ed Schippers 3 years ago in IQANdesign • updated by Gustav Widén (System support) 3 years ago • 3
After I upgraded my program it generates an error, i use cycle time and the error stats that the the name is not unique. the is not the case, copying the code in a function in the application it will generate no error
code used in the evend log:
Image 4131
Same code but used in an ID in the application:
Image 4132
In your application, does the channel have public scope?
There is a problem in 7.01 with Qcode expressions in logs that refer to channels in function groups that have public scope.
7.02 will fix this problem.
Yes it is public.
For the moment we use a workaround using an ID in the application
Planned
Thank you, then it is the problem that is being fixed for 7.02.
I changed the topic title to describe the issue.
