else if
Grumpy Vern 3 years ago in IQANdesign • updated by Christopher Fridstaden 3 years ago • 1
Do consecutive else if statements stop at the first true? For example, I expect the code below makes result = 3.
if false then
result:=1
elseif false then
result:=2
elseif true then
result:=3
elseif true then
result:=4
else
result:=5
endif
Yes, the conditional statements are evaluated from top to bottom. The code for the first statement to be evaluated as TRUE will be run and that will "break" the if-then-else and the code below will be run.
